Re: 89 v-135. anyone know how to adjust air:fuel ratio on this thing? + a timing ques
By your original post, i deduced that you don't even know what the carb on this thing looks like.
How long have you owned the motor?
Did the last owner, or "mechanic" that messed with this thing know what he was doing?
What are the odds the pointer is in the right location?
What odds do you want to take on the bomb bit?
I have one in the yard now that should run like a scalded dog. The owner said it never has, but takes about 15 - 20 seconds to get on plane.
When I checked it out I found.
1. At a glance, the linkage is off at least 15?.
2. The oil alert is dead. (owner didn't even know it had one)
3. Wrong lube in the LU
Amazingly, it isn't hurt too bad yet, but I think the owner will think I put a 200 powerhead on his 135 when he next runs it.
Do you think I'm going to time it assuming the pointer is in the right place?
A cheap Chinese (harbor freight or Menards) dial caliper can be used for the depth gauge.
hope it helps
John
