I just bought a 89 Wellcraft with a 3.0 Merc. the boat is in mint condition except the owner says it gets water in the Oil, I acctually will be picking the boat up this weekend so I have not looked into the engine yet (the price was right) he was told the block is cracked. but he is by no means very Knowledgable on his boat! but he has always had it serviced at a marina. the boat does run, and seems fine out of the water. I have no idea how long it takes to get water in it andit was supposidly winterized!
so a few questions. since it runs I assume it can't be a head gasket. so i plan on first removeing the manifold and checking it. if it is ok, then what?
and can a car 3.0 block be used if I swap out all the parts? I can rebuild the engine but not familiar with what is interchangable with my 89 3.0! can anything else drop in? V6 V8 do I need to find a Marine block? any tips and pointers would be helpfull. this boat you could eat off the current engine, thier is not one drop of oil or dirt in the engine bay! is their anyplace this engine block comonly cracks and would it be repairable? since it runs out of water I assume a water jacket someplace, but I will also do a compression test when I get it home!
thanks
if the in
thanks
if the in
