I have been trying to get this motor back to full power since last year... top end works for a little while then gets "4-strokey", "flutter sound" and loss of power, won't go to WOT after a little while.<br /><br />Smells rich.<br /><br />I have rebuilt carb, new points, condensor, setup gap and timing. <br /><br />Looking at fuel pump this weekend, inner diaphram is very thin/floppy... may be normal.<br /><br />? If the diaphram were to leak, wouldn't this cause fuel to enter the "intake" area under the pistons? This would cause motor to run fine for a while then get too rich when this extra fuel builds up..... what do you think, am I on to something here?<br /><br />Rebuild kits all look wrong, this pump is a rectangle about the size of pack of smokes. It seems to have same mount as the newer square small pumps... holes line up... <br /><br />Can I substitute a new "newer" model pump?<br />What is part number for the correct rebuild kit for this pump (motor is MQ-10)?
