9.5 Evenrude
Mwj
Hi, need a little help. Motor starts but only stays running by squirting gas in carb. So I cleaned carb and blew out. reasemled. No luck. I replaced the top half of carb body with float assembly that I Knew worked...... no luck. Question is where is it plugged?
tphoyt
Will it stay running if you squeeze the ball?
If so verify the fuel pump is working.
kbait
Reed valve leaves broken/blocked open {directly beneath carb)?
I suggest you find the orifice plug ( high speed ) in the carburetor bowl.----Make sure it is clean.
