9.5 evinrude
pickles
i have just aquired an old 9.5 evinrude mod #10522c ser#c467820 can anyone tell me the year it was made , and gas to oil ratio.<br />thanks <br />the sad tramp
bubbakat
Re: 9.5 evinrude
1965 10522<br />fuel mix 50;1<br />plugs champion J4C gap at 30
pickles
Re: 9.5 evinrude
thanks bubbacat , but are you sure it,s 1965 it dos,nt look that old , but then nether do i HUH .<br />the sad tramp
jfm1
Re: 9.5 evinrude
yes it is a 1965 like bubbakat said
pickles
Re: 9.5 evinrude
thanks guys<br />i have just lifted the hood on this thing and theres a splinned nylon cup on the end of the lean/rich mixture knob with metal linkage on it ,can,nt seem to see where it attaches to can any one help.<br />the sad tramp
bubbakat
Re: 9.5 evinrude
It should be hooked to a small like cable that goes back to the carb.<br />I'll look through my pictures and see if I can drum up one that shows it.
Chinewalker
Re: 9.5 evinrude
Hi Bubbakat,<br /> The earliest 9.5s had two nylon arms with a bent metal rod between them. It didn't work too well stretch over the space from the cowling all the way back to the carb, so they went to the flexible cable. The nylon arms were much like those used on other motors with knobs somewhat removed from the needles... they actuated...<br /><br />- Scott
pickles
Re: 9.5 evinrude
Hi Bubbakat<br />I have found out by trial and error that the linkage go,s to a needle valve on the carb, but it only give you about half a turn on the valve, do you know how to setup the rich/lean mixture,? i can screw the needle all the way in and out by hand but it dos,nt seem to make a differance of the running of the motor i,d like to get it right don,nt want to burn anymore gas than i have to all ready paying to much for the stuff. thank for help <br />The Happy Hobo
