9.5 motor mount rework? Redesigned part possible?
dockrat100
I have a 1967 Johnson 9.5 hp. My top front motor mount is broken (Part # 380963) This is, I have heard, a common problem. I have also been amazed at how expensive a few pieces of plate steel and a chunk of rubber can be made to cost. Somewhere between $50 and $100, depending on the site.
Has anyone found a way to rework or repair their existing motor mounts to make them better, or at least cheaper? I have an idea that may work, but I do not want to reinvent the wheel here. If someone has a better idea that works, let's hear it.
What if you drilled a hole through both plates of steel, and the rubber mount, and added an additional rubber shock and washer to the outside? Would that not give rubber cushioning in both directions, but limit the movement allowed to the length of the bolt, so you are not depending on the strength of the rubber to prevent the mount from tearing in half?
Not sure if you can draw a mental picture from what I have said. I will try to draw something later.
F_R
Re: 9.5 motor mount rework? Redesigned part possible?
It has been reported that Devcon will glue it back together. Disclaimer: I haven't tried it.
I have never seen a lasting bolt-it-together fix. Let us know if you come up with a better plan.
Faztbullet
Call this fellow as I was up there last week and he had a zip-lock bag full of these NOS, and he has a BRAND new factory powerhead still on board that can be bought right!!!!!
http://oldoutboardbarn.com/
dockrat100
I know I can find the parts, I just find it hard to swallow that such a simple part has to cost between $50 and $100. There must be a better way.
nwcove
could the guy that makes the obsolete impellers rebuild that part? ( just a thought!)
