Re: 9.5 prop question
If you check the prop store here you will see that props are the same 64-73.
If the motor has been performing well be sure to get the same prop size.
If your thinking of changing size get your present max rpm and speed first.
wrong size prop can spell disaster for your motor.You could get your present prop repaired.
