9.8 Mercury 110 - Water flow from Exhaust plate onwards...
rruberto
Hello All, I have taken out the exhaust plate and water jacket (where the spark plugs are) and the amount of debree that came out was not even funny!
Anywise, i noticed that under the exhaust plate there is a duct that starts from the bottom left corner of the exhaust and goes all around the exhaust (excluding the bottom left to bottom right). On the bottom left of the duct i noticed a hole that if water is sprayed in it will come out of the tell-tale. On the bottom right (of the exhaust) there is another hole that connects to the water jackets). Between the top right and the bottom right there are about 3 holes that connect eachother, which pass by the water jackets.
Additionally, on the bottom center (of the exhaust) there is a larger hole that if water is sprayed in it will reach the flush hole near the tell-tale. However, the larger hole gets covered by the exhaust plate and seems not to have any function to me.
NOW, my question is "how does the water from the water pump reach the exhaust water duct and circulate to the water jackets and out to the tell tale??????
(1) the hole at the bollow left of the exhaust.
(2) the hole at the botto right of the exhaust.
(3) a hole that is soo clogged up that i did not even see?
Thanks guys, that stupid manual does not explain how the water circulates!
