9.8 Mercury (Lower unit)
erniex
Try having someone rotate the flywheel a little by hand as you try to push it on. This will help the splines align. If the lower unit is in gear, you can also turn the prop.
Donald Horne
I changsd the impeller and I can't get the shaft to lign up to go back on. Is there a trick to this. This is the third time I've put an impleller on this old motor. I have trouble every time. Serial # 2937164.<br /><br />Thanks
