Re: 9.8 nissan slow jet
What model 9.8 are you working on?
If you're talking about the NS9.8A, are you also talking about the idle mixture screw (up high on the outboard/starboard side of the carb)? If so, did you drill out the brass EPA plug to get access to it?
If that's the screw in question, it is not supposed to be all the way in. The specific adjustment will be somewhere around two turns out, but each motor/carb setup needs to be tweaked for the exact correct idle mixture. Do NOT ram the screw in all the way, as the tip is very small and delicate. Lightly seat it, back out 2 turns, start and warm up the motor, then idle slowly, and adjust for reliable mixture (best slow idle RPM). If you jammed the screw in too tight, you may have damaged the tip of the screw, or the tiny brass jet in the carb body. If so, you will probably have trouble finding parts, and will likely need a new carb.
