9.8 tahatsu rope will not pull
whybark
I have had this motor for years. It is a four stroke. I think around 2015. Of course the rope will not pull when in gear. I was at the lake the other day. I pulled the rope 3 times, then the fourth time it will not pull. I checked and the motor is in neutral. I have no idea why I can not pull the rope. Any ideas??
whybark
I checked that. When I try to pull the rope in gear the safety ingages and the rope will not move an inch. When I pull the rope in neutral the rope moves a few inches
whybark
OK, I guess I left out a little info. I transported my motor the day before. I guess I put it on the wrong side. Oil drained into the cylinders.
whybark
And it did not cost me an arm and a leg. I am no mechanic. But I can remove a couple of spark plugs. But I did ruin a good shirt when I pulled the rope and the oil came flying out.
MattFL
All good decisions come from experience, and all experience comes from bad decisions. What you have gained is experience.
Sea Rider
Pull the cord several times till all the flooded oil is out, put plugs back in and test if all works as used to do so...
Happy Boating
