catalyst-519
- Joined
- Mar 12, 2008
- 64
Hey Guys.
Ripped the head apart on my 76' 9.9 due to a bad gel seal. But now when I've dry fit the two halves of the case together they dont sit exactly flush. When one side is flush the other side raises up about .5 mm
The centre bearing and connecting rod bearings are lined up and positioned in ine with the locating pins.
I'm thinking this means either a slightly bent crank or warped crank case half. Any other ideas that could be interfering with the seating of this half?
If I use a healthy amount of seal and slowly torque it back down will this slight warping matter? (supposing that's the issue).
Thanks
Thanks
