9.9 evinrude water intake tube length
CALL2255
changing from sailboat shaft and need to know how much to cut off copper intake? also how do i do it. thanks
PW2
Re: 9.9 evinrude water intake tube length
When changing shaft lengths, you have to change a lot more than the water tube length.
CALL2255
already changed drive shaft and shift lever from sail drive shaft to short shaft thanks
Chinewalker
If you're going from Extra long shaft (25) to short shaft (15), you take 10-inches off. If going from long shaft to short shaft, take 5-inches off. Make sure to "dull" the edges of the water tube so that it won't catch the grommet in the impeller housing. Some 220-grit sandpaper to round the edges works fine...
- Scott
JCF350
Cut off the same length as the long shaft adapter housing you removed.
