reload
- Joined
- Jun 29, 2004
- 368
Please allow me to recap. I bought this motor on a boat. It had not been ran in several years (maybe 10). I fooled with it for about ten minutes and it fired up and ran great. I decided to take it for a test ride the following weekend. It quit running after a short period of time. I figured it overheated. I tore it down and replaced the thermostat and some gaskets, water tube and some seals and the water pump. It ran great after that, this is when I discovered the pee hole, it had great water flow after working on it.<br /><br />I have asked this question several times of many different people. Is the water coming out of the pee hole suppose to be warm cold hot or whatever. I have had answers from the same temp as the bay water to almost hot enough to burn you. Does anyone really know what the temp of the discharge out the pee hole is suppose to be?<br /><br />Please if you don't really know don't answer. The motor is a 1978.<br /><br />Paul
