My 2011 9.9 hp manual start motor would always start on the first pull, run and idle great. Recently, it would start and run fine. After I killed it with the 'off' switch and let it sit, it wouldn't start --not even hit, but would start later. Now, it won't start at all. I removed the plugs and squirted a bit of starting fluid into the cylinders, and it still doesn't hit. I'm thinking I have a defective 'on-off' switch. Could this be the problem? If so, how do I easily check the switch?
