9.9 HP Yamaha gets no power in reverse
Cat27
Hello,
Recently the 9.9 HP Yamaha OB I have on my sail boat has zero driving power in reverse. Forward works as it should but no drive whatsoever backwards.
I looked at the shifting cable and its connections are good and fully engages the lever. I know next to nothing about boat motors; but I tried shifting it into gear with the motor off and in forward the prop doesn’t spin but in reverse it spins freely; based on some internet reading this leads me to believe it’s a spun prop but I don’t see how it could be spun in reverse and not in forward. I’m pretty perplexed on this and any help would be appreciated.
99yam40
I would think from what you wrote, it is not going into reverse, so you will need to find out what in the linkage or the lower unit is not doing what it should be doing.
Oh yea it would help if you tell what 9,9 the motor is
Cat27
It’s a 2009 T9.9LL.
Cat27
No, I’m On the north coast of Washington, although it’s very possible to motor was purchased in Canada since me and the prior owner are within 30 minutes of the border; although I just bought the boat and am not certain on the provenance of its parts.
Is this OB not available in the states?
99yam40
Boscoe will drop by and tell what USA model is the same as yours or at least real close
but you will still need to find what is not doing what it should be doing to get the lower unit into reverse
Cat27
Awesome! is Boscoe an expert or a Yamaha rep or something? I’m new to the community.
Thank you so much! I really appreciate the help.
