My sons first boat and motor. I try to help him as much as I can but he lives with his mother so I dont get many teachable moments with him.
9.9 1977 Johnson long shaft. Last August he tore up the lower unit gears. I bought a 1985 complete LU short shaft. I took my long shaft and shift rod and swapped units. Replaced the water pump with a KIT and pressure tested it. Ran it in a barrel and it pee'd fine and warmed up good. Good fix with lots of input from iBoats.
He took it out another 4 times or so and says "dad, it runs and shifts great". Then he looks at it after an outing and sees this oil.
I tell him not to take it out but he does anyway. Says it is peeing but block is hot. This was last October. Going to look at it for him this week. (We are in Ohio. All iced up....). Here's my plan:
Look for peeling paint
Compression check
Pull the lower unit and inspect the impeller.
He runs shallow water a lot. Try to back flush the water jacket with a hookup to the bottom of the water tube. Flush any sediment.
Pull the water jacket and test the thermostat
punt
Reading here leads me to think he cooked the head gasket and the water and compustion sides are connecting. Is this the reason for the dark fluid at the water discharge?
Any thoughts will be appreciated.
Compression check
punt
