9.9 lower crankshaft bearing shot
Robj
Hello, I am working on a mid 1980's 9.9 Evinrude. I want to change the lower crankshaft bearing. The only number I can see is 6204. Does anyone know of a cross reference for this bearing or do I need to get it from BRP? Thanks.
boobie
Re: 9.9 lower crankshaft bearing shot
Is that the # on the brg ??
Robj
Yes it is, but I know there is more to it than just those numbers. I can but a 6204 bearing at Lowes, while it may fit, I am sure it is not the correct bearing.
the machinist
The outboard motor companies along with most others do not make all their parts. Bearings are one & that is a common bearing number. Yes, just go to a automotive dealer or if you can get it at Lowes, it will be the same no matter where you buy it.
boobie
Agree + 1............
Robj
The bearing at Lowes was an enclosed bearing, while the OEM one is not. I know there are other numbers that go after the 6204, that specify other characteristics of the bearing. I will go to the autoparts store to see if I can match it. I will post what i find.
bwkre
If it is a 6204 I believe there would be several choices. 2Rs would be sealed and a ZZ would be shielded. In either case you could pop the seals / shields off and have an open bearing. Then simply wash the grease out with a solvent. The only other option might be a high speed application bearing that will have a greater bearing tolerance to allow for expansion due to heat. In the case of an outboard it would be a standard bearing.
