I'm running a 1997 Johnson Sailmaster with the standard 10 x 7 prop. (I think) on a full keel sailboat that displaces 6400 LBS. on 18'1" LWL. I've calculated that my max. hull speed should be 5.7 knots & that theoretically 9.3 HP would be all I would need to push the boat to hull speed. However on my boat I rev the heck out of the engine & can only get 3 knots max. The motor is properly submerged in the water so ventilation should not be the problem. So I'm thinking it could be the prop that needs replacing. <br /><br />The engine does sit in a lazarette locker & so the lower unit (w/prop) never tilts up when the boat is in the water (but antifouling is used). <br /><br />What is the largest diameter prop./pitch combo that can fit on this model motor & will that get me up to hull speed? <br /><br />Any help or first hand experience would be appreciated!<br /><br />Thanks, <br />Chris
