JSGOLD
- Joined
- Sep 22, 2009
- 609
We are replacing an old tired 55hp with a 9.9 remote Mercury motor on our old StarCraft boat deep V. We use it almost always at 10hp max lakes so speed is not a concern. Just tired of dragging the 55 along and having to use a 8hp tiller so much. My question is this...The transom on this boat is between 19-20" in center. The 9.9 I have is a long shaft but I notice that the water intake on it is a bit higher than either the 55 or the old 8hp long shaft and the cavitation plate may be even or slightly above the bottom most point. This area has to be submerged since the water intake is under it. Now on this boat the bottom of the transom is always about 5-6" below water anyway. But, am going from a 240 lb motor to one about 100 so unsure how far below it will go. I can always install the motor off center but am pretty sure it will be OK. Do any of you have a similar situation? I guess if it raises up enough I can add weight back there.
