boater1234
- Joined
- Jan 6, 2010
- 869
Hey guys i just had a few questions.The first question i have is i have a new 9.9hp 2stroke yamaha and i have heard from almost anyone who knows these motors that the 15 is the exact same motor except for the reed valves behind the carb.I was wondering if anyone has modified a 9.9 yamaha into a 15?Also was it a major power difference.
The people i bought the motor from said the 9.9 and 15 were so close you really couldn't feel much of a difference.I can't see how that can be true when your increasing your power by 50%.There has to be a big difference wouldn't there be?I mean i know it's not going to be crazy power but i would figure at least 3 to 5mph and a ton better torque at the least.I took my jon boat out today and need that extra power and speed as it is just lacking for the boat i have.It's a 1442 rated for a 25 but i was told from a ton of people a 25 would be to much for a 200lb jon boat so i went with the 9.9 2stroke as they didn't have any 15 2strokes left.I may need to go to a 20hp 4stroke if needed but i'm sure if i modify the 9.9 to a 15 it will do the trick
So i figure if i get it up to a 15 it should be perfect for the boat.
The other question i have is what is usually the best trim to keep it on.It has 5 settings and it seems like the second hole up from the bottom is the best.I was just wondering if anyone has found what works best for a jon boat.I was actually suprised at how much power that little motor had but i need just a bit more and i'm hopeing that a 5hp increase will do the trick.I have also heard once the motor is fully broken in it will perform better with time on the motor.Ok any help would be great thanks guys.
