Got my first boat this spring and have been working to restore it to a decent condition. 14ft Fiberglass semi-v w/ Mariner 9.9M. Should work out well for fishing once I get everything in good working order.
Laddies previously identified this motor as being a 1982 model.
Here's my problem. I've taken it out 4 times this year fishing and each time motor will start and run great for about an hour and then it'll miss out for a few seconds and just die and won't start back. After a few hours it'll start back and my run for a a while but will eventually do the same thing. At first I thought it was the plugs so changed them and same thing continues to happen. Thought it was bad gas since part of my tank was left from last year, so I got new gas (mixed 50:1). Still same thing happens. Fuel filter is clean. Motor just acts like its not firing.
Luckily, my trolling motor has been able to get me back to the dock.
Previous owner used it past 2 summers without any problems and took proper care of the engine in the off season.
I have ordered a Mariner repair manual, and am waiting for it to arrive. Thought some of you might be able to give me some suggestions about where to start. How do I check to make sure the plugs are firing?
Thanks
Thanks
