90' 120hp lower unit won't come off
moodyscruz
I have a 1990 120 evinrude and I can't get the lower unit to come down. I have all the bolts out and the shift lever disconnected, I've been beating and prying but it still won't come off,,, any suggestions.. I removed the 4 bolts on the gear housing and the bolt under the trim tab, the trim tab and I even took off the bolt holding the zink on... I'm open for any help. Thanks:mad:
tashasdaddy
Re: 90' 120hp lower unit won't come off
take the spark plugs out. turn the flywheel sounds as if you have rusted spline in the crank shaft.
