Re: 90 150 Force Wont start back up
By 'blow by' you mean the tank spits back at you when filling? I believe that's somewhat normal.
The running issue: Check your fuel pump's diaphram for cracks and/or leaks. If pumping the bulb gets you going but it won't keep running, it sounds like you are not getting enough fuel pressure to fill the float bowls.
Good Luck!
