'90 70 HP power tilt and trim issue, dead motor??
eph
I have a 90 70 HP Evinrude, was out yesterday tilt and trim seemed to be working well, when I got home and tilted the motor it seemed slow, tried again this morning, got it to work a few times was still slow, then nothing, from both the throttle and the motor. There is no noise when I hit the switch, 90% of the time, the other 10% the pistons barely move. Battery is 100%, fluid is 100% full, any ideas?
ezeke
Re: '90 70 HP power tilt and trim issue, dead motor??
Clean the contacts on the relays and try it again.
tashasdaddy
and cables.
mikesea
You can follow up the wire from the motor.Disconnect the blue and green wires and using a heavy wiring,jumper cables will be perfect,jump to a battery blue to positive (bluesky=up)grn to neg is up.reverse down(grass green=down)if it still runs slow,motor likely going bad
