mbroughton02
- Joined
- Jan 17, 2015
- 198
1981 Evinrude 90 won't start on its own after it's been sitting awhile. I could crank it for days and nothing happens.
When I crank the engine with the key pushed in, no fuel is being delivered through the primer solenoid. I can take an outlet hose off the solenoid and see this.
I know the solenoid itself is working because if I have someone else hold the key in and squeeze the bulb, fuel flows through the primer solenoid just fine. To get it started if I'm by myself, I will engage the manual start lever on the primer solenoid and squeeze the bulb a few times. I then can put the lever back, squeeze the bulb 1 or 2 times until firm, and the engine will start immediately.
Engine runs great once it's started. Idle to WOT no issue at all. Could this be a faulty fuel pump? What is it that is supposed to make fuel flow through the primer solenoid when the solenoid is engaged?
