Re: 90 horse carb problem???
I have the same problem on the same engine. Starts great, runs smooth just no power when you open it up. I'm on a 14' Sea Rayder which should be hitting 40 mph. Right now can only hit 28. Slow to get out of the hole as well.
Pulled the plugs, 1 & 2 were carboned up pretty good. #3 was very clean
Replaced plugs & fuel filter - only saw a 1 mph improvement.
Good spark to all three plugs. I pulled the wires of each and noticed a corosponding drop in RPM & roughness each time.
Don't have a compression checker but the "thumb test" showed impressive compression out of each hole.
Inspected throttle advance on each carb and they are all advancing properly. I did not remove cowling or confirm the butterflys are in fact opening.
Could I be looking on the wrong end? The impeller looked OK. No damage or fouling but I did not remove it.
I'll pull the cowling and check the butterflys. Assuming thats OK, what should be next?
