90 HP 4 stroke does not cycle fuel pump when key is turned on
FredReich
2013 Mercury 90 HP ELPTO 4 stroke.
When I turn on the key, the fuel pumps do not come on.
I already verified the pumps will run if given current.
I used a multimeter and determined that no power is coming into the quick connect plug that comes out of the fuel pump container.
Motor will turn over fine.
I need some guidance to trace the problem between the quick connect and the ignition switch.
Any help to divide and conquer is appreciated.
