misery
- Joined
- Jul 18, 2010
- 98
Hi all. My 86 90 hp evinrude has a funny problem with the tilt/trim feature. Whenever I tilt the motor up to the trailer position, the trim rams are fully extended, which I assume is normal. The problem occurs when I try to lower the motor after launching when i press the trim down button one trim ram will go down then the other, then finally the tilt ram starts to go down but when it reaches about the mid way point it basically goes into free fall. I just put this motor on this boat this summer and the wiring was disconnected from the the trim control box on the back of the motor so is it possible I fudged it up or am I just fretting about nothing?
