90 HP Force - After idling, dies
springhead
Hey Tami
try replacing the fuel pump diaphram.
It comes in a kit with rubber diaphram and gaskets.
its under 10 bucks.
also try the primer bulb and check for water in the gas.
all are easy to change and inexspensive.
Good Luck
jaime
Re: 90 HP Force - After idling, dies
Tami said:
I have a 90HP Force engine. I believe it is a 93. It runs fine, but after idling for a while, when I put it in gear, it dies, then is very difficult to get started again. What could be the problem?
Hey I am having the same prob so I am trying to adjust my carb BUT. Can't locate the 2 screws that are shown in my service manual for my force 90 diagram?
jaime
Hey I am having the same prob so I am trying to adjust my carb BUT. Can't locate the 2 screws that are shown in my service manual for my force 90 diagram?:$
steelespike
I don't have info for your motor but if it uses a Tillotson carb The screw is right on the front.Above the opening.
