biederboat
- Joined
- Feb 13, 2005
- 83
Some of you may have been following my saga on a 1996 Force 90 HP. It had a frozen piston due to a leaking head gasket. I "resurrected" the scored cylinder and it's within 10% compression of the other two. Took it out for a test drive finally, when it runs it sounds and feels good. However, it is stalling (totally dies) after it runs a bit (at high speed). Any ideas? Cranking it over without the fuel line connected to the carbs shows fuel coming out while cranking (but it's left over and not sure how old). I was going to change plugs, run off a small tank, maybe clean out carbs and/or try some B-12. Oh yeah, change fuel filter too and if none of that works maybe rebuild fuel pump. Any ideas how I could further istolate this problem?
Thanks,
Biederboat
Thanks,
Biederboat
