I am a auto mechanic trying to repair an outboard motor and I sure do like I-boats.com.<br /><br />I am working on a 90 HP Johnson (or near that with a black cover v-4, 2-cycle.) that is leaking Injection oil into the fuel line and into the carbs carb. The motor was used once this year and is on a pontoon boat. I drained blue oil out of the carb drains. I used 1/2 can of starting fluid to start the engine and burn out the execive oil. It is running fine now and idles normal. <br /><br />Is it a bad oil injection pump, Oil tank vent, or other problem. I guess this could be a common repair job that I an not aware of. <br /><br />Thanks, Pat F.
