newbassboat
- Joined
- Jan 30, 2006
- 53
I have just recently purchased my first Bass Boat. It is a 1990 Alumacraft with a 90 HP Johnson attached to a 115 hp motor bracket. The power trim / tilt (attached to the motor bracket) will not go down, but will go up. I traced out the wiring and to go down it goes through a Selenoid (which is definatly bad) and to go up it is wired directly to the TNT Motor. Is this correct? I would think that you would want a selenoid to go up if any. It is a 3 wire TNT Motor. Does anyone know how it should be wired or maybe have a schmatic, ect.
