Thanks guys, at least that gives me a few things to check, its a stainless prop so its not a spun hub, I did hit something a fair while back but havnt had any trouble till now, Was in open water and when I throttled up it just threw itself out of gear, but yeah looks like lower unit is coming off, will drain the oil and see whats in it first tho
Mark, The clutch dog pin attaches it to the plunger that moves the clutch dog. The clutch dog is splined to the prop shaft, and the two gears ride on bushings. It is unlikely the clutch pin will break, as the shift linkage would be the only way they would happen, and it is not the weakest part by far.
