90 HP Mercury Force - Tilt problem
aaronm
I have a 90 HP Mercury Force, circa early 90's and the tilt only goes up and not down. It has 2 relays that control it and it clicks when you try to go down. I thought the problem may be relay related and I switched the two relays to check with no luck. It's full of fluid. Any other tests I can perform ?
JB
Re: 90 HP Mercury Force - Tilt problem
Moving to Force Troubles
