90 hp mercury leaking oil
Pmbcustoms
The boat will not start so I was checking the oil in my 2008 mercury 90hp while I had the top off and when I pulled the dip stick out oil came rushing out of the filler tube had a gas smell as well. Any ideas would be helpful. Thanks
Chris1956
I would expect that the oil has water in it. You should repost this in the Mercury forum.
Smell like gasoline ?----Perhaps a leaking fuel pump or carburetors if it has those.
Pmbcustoms
I have had fuel pump problems all last summer. what would be forcing oil out of the filler tube when you check the oil. Could it be water/gas in the Block
Chris1956
Gasoline would mix with the oil, diluting it.
Alternatively, oil will float on water, without mixing. It could then bubble up out of the dipstick.
