I let my boat sit for too long and have gummed up the fuel system. I took the Vapor separator apart and cleaned it up. The boost pump had a lot of nasty gunk, I cleaned it up with carb cleaner and hooked it up to a 12v battery and could hear it running. the needle valve was stuck cleaned it up and got it working. The high pressure pump looked very clean but I still sprayed some carb cleaner in it just for good measure. I put it back together and the motor started right away. It ran for a few min's and then died. I am a novice on working on boat engines so I was wondering what should my next step to clean this fuel system up? Any help would be greatly appreciated.
