Re: 90 hp prop shaft seals
No special tools required fcryon. Although a slide hammer sometimes helps in removing the bearing carrier....what your calling the prop hub. The thrust bushing should slide off the prop shaft. It's probably stuck. Stick a large screwdriver under it and pop it lose.
