OK I am missing the sound attenuator assembly on my 1995 90 hp sportjet engine. This is an image I found online of what my assembly should look like you can see a hose running out the bottom labeled "to fuel enrichner". I am uncertain of were and how this actually connects. This is what that attenuator should look like.
I could not find this assembly anywhere. I did however find another older style assembly that I picked up but have yet to install. It has the extra connection from the bottom instead of between the 2nd and third carb but should work. Anyway I am just trying to figure out how exactly it connects. If anyone knows were to get the assembly like the one in the picture it would be greatly appreciated.
Here is a diagram of the auto enrichner. I see hoses going to every connection but the one I have pointed out. It has no label so I am not even sure if anything actually connects there. If not where would the hose coming from between the 2nd and 3rd carb connect? If that is were is goes then if anyone else has this engine could you verify that for me? Thanks for any help.
