90 hp yamaha speedometer
Gary85_
I have a 2007 skeeter with a 90 yamaha on it, one day the speedo just quit. I read some posts here with same problem but did not see an answer that would help my situation. My inlet tube is in the foot of motor, tube is clogged inside the foot. I have a small rectangle hole in casing to allow water, this IS open. Took a flashlight and looked in the opening and seen the tube coming from the top, but not seeing the exact opening for the pitot itself. Undid the tube right above foot where it comes out of casing and blew 100 psi air back thru but nothing coming out, all its doing is expanding the tubing. Any ideas would be greatly appreciated!!!!
Gary85_
Re: 90 hp yamaha speedometer
Just begging for help...any comments will be considered and replied to.
Gary85_
I thought maybe some pics would help...
TheFin
Thats not the right hole.
Look for a small (approx 1/16") hole in the front of the lower unit below the cavitation plate.
Gary85_
Thank you sooooo much.... I can't believe i didn't see that one. OK here is a shot for future help. Again thank you for your help...oh btw it WAS plugged.
Gary85_
Thanks appreciated..but just glad it helped someone else!!!!
