90' johnson getting hot.
bernieb
model #ve90 tLesb and the water pump has been changed .does this motor have a thermostat,and a so-called pop-it valve ? I haven't looked at this motor yet and i'm told that water is coming out the pisser.Horn has been going off now and then.....any ideas thanks
reeldutch
Re: 90' johnson getting hot.
may be stuck closed tstats or swolen water deflectors that prevent circulating the water in the heads.<br />may be the waterpump is installed wrong and there is no sufficient water pressure.<br /><br />we need more info
OBJ
A hot horn going off "every now and then" sometimes points to a different problem than impeller and t-stats. Do you know under what circumstances the horn alarm....WOT, at idle, mid range....etc. <br /><br />The tell tale stream comes from the bottom of the exhaust cover. The hose from the connection on the exhaust cover to the tell tale hole on the pan should route up and over the starboard head. This is to help the engine stay full of water and prevent it from getting air bound.<br /><br />Any info you could give us would be beneficial...
