Was starting fine with ignition switch previously... shut it down for a while and then turned the key to start, and nothing, starter does not respond... starts ok by jumping the solenoid terminals with a screwdriver. So I figure it's either the solenoid or the ignition switch...
Suspecting the solenoid, but would appreciate suggestions for a test procedure to isolate the cause...
thanks in advance for the help.
