90 Merc No Compression on #2
hsi111
I have a 2000 Mercury 90hp 2 Stroke that has 0 psi on #2. 1 and 3 cylinders each have 118 psi. I tried to look in the spark plug hole...all I can see is part of piston and it looks ok. No shavings found. What are possible causes. Is there anything to check without pulling power head? Ref: model 90elpto, serial 0T072541. Thanks, Rick
Ebrooker007
Re: 90 Merc No Compression on #2
You can get a better look at the condition of the cylinder walls and position if you take the exhaust cover off the side of the engine.
hsi111
Thanks, I'll do that. Wasn't sure if I could see anything in there.
hsi111
ok, I pulled exhaust cover real quick and the piston was sitting right where it needed to be. It's not pretty. Rings are smashed together and piston is a little melted. I just hope this thing can be rebuilt. Thanks for your input.
Toddboat
If there's no major damage to the cylinder walls, you can rebuild it yourself. Just buy a new piston and rings and get a cylinder honing tool (google "ball hone" for images). It's a bit that goes on your power drill. You move it in and out of the cylinder while it's spinning to make the 45 degree score marks in the cylinder. It's a big job, but it's a fun project. Take a lot of pictures as you take the motor apart so you know how to put it all back together.
hsi111
Does anyone know of a link to a service manual for this engine or have one that they can send me. Thanks, Rick
