1987 merc (3 cyl) started up & ran fine after winter storage.1st spring run no problem. Following week it would not start,no spark turns over fine, please advise.(mecury switch is OK)
Get manual and ohm out the stator, then the trigger. Failing that suspect the switchbox.<br /><br />I'm assuming all wiring and ignition switch is OK and tested.<br /><br />-W
