90 vs 115
stemar
Hello<br />I have 90hp outboard on rigid boat which wot is 42mph. How many mph will do more if I put on the boat 115hp outboard?<br />Thanks
Re: 90 vs 115
A Couple mph,............ Maybe..........
JB
Re: 90 vs 115
Outboard Non-repair topic.
ivar
Re: 90 vs 115
A rule of thumb that I've found somewhat accurate , is that the speed increase in % will be half of the HP increase in %. <br />So say you increase HP 20% to ~110HP , your speed should then increase 10%, or by ~4mph.
pine island fred
Re: 90 vs 115
Agree, dont think you will see much of a difference in that power range. fred
swist
Re: 90 vs 115
If the 115 is a lot heavier, you might see no improvement at all, or even a slowdown.
jim dozier
Re: 90 vs 115
Just this year I replaced a 85hp Suzuki with a 115 hp Evinrude on 17.5 bowrider which has a pad semi-V hull. Both engines were running good. The 85 hp pushed the boat at 40 mph GPS and the 115 pushed the boat at 49 mph GPS with a Stainless prop and a jackplate. 9mph improvement and much better hole shot. Average fuel consumption for a trip to my usual spot 6 gallons for the 85hp, 7 gallons for the 115hp. I might add that there was a 4 mph difference with 2 props I tested on the 115hp. Based on your 42 mph I would guess you could hope for 49-51 mph top speed with the best prop. Hope this helps.
Dhadley
Re: 90 vs 115
Also depends on models. If you repalce a 90 crossflow with a 90 looper youll think someone strapped a rocket on there.
sassboater
Re: 90 vs 115
replaced my 86 johnson 90 with a reman 89 110 evinrude on 17 ft. aquasport cc and gained 4mph but using more gas.
walleyehed
Re: 90 vs 115
As Dhadley said, if it's the x-flow/looper change, yea, it'll be a good gain...<br />If it's a x-flow to x-flow, I don't think you'll see 3mph gain.
