Re: 90hp 1979 inline 6, choke question..the rest of the story..
Just bought this boat/motor a month ago. Knew right at the start it needed a new starter. Ordered one. In the meantime while waiting for the new starter I was trying figure out how to get it to start easier.
You Guys confirmed the 2 chokes was correct.
New starter arrived.
I installed it, figured i'd try it make shure it was ok.
I have a cut down barrel for under the motor, put it under and filled it with water.
squeezed the bulb till it was hard and them some.
Turned the key on, pushed in for choke and cranked, starter seemed to work good.
After about 5 seconds just as I was letting up on the key it started!
I let it warm up, idled it down, let it run for a while, then shut it off.
I was amazed. I let it cool down for a couple of hours, and started it again, popped right off again the first try. spent the rest of the day doing that, started it about a dozen times....Im Happy.
What happened? My best guess is this..
The old starter was drawing so much current it was dropping the voltage to about 9 volts even with a fully charged battery...aparently too low for the ignition to properly fire the plugs. New starter never drops it to less than 11.5volts.
Thanks for the replies....
