Well we bought a new 90 hp 2012 e-tec to put on a 20' Lowe Trinidad pontoon and we were set up w/ a 14-11 3 blade aluminum prop.
Problem is 1)we cavitiate occasionally and the motor is set all the way down.
2)Full throttle RPM's (per gauge) is about 5200. Evinrude recommends 5000.
now the question is we need probably a slightly bigger pitch and was wondering if a slightly different diameter would also be recommended. Would that help the cavitation issue? Usually occurs at mid-high throttle range and is somewhat tilt dependent. I don't expect trim/planing miracles but it does seem when I get the nose up a bit too high w/ the 2 of us in the back it occurs more frequently..seem odd to me.
Next thing is I do have a prop (4 blade Vortex 14-21) that I meant to try for fun and to see "what it does"..
Problem is I need a hub (interchangeable) since my current insert is for a Merc. Alpha drive. Mich. Wheel chart is confusing and I'm not sure which one (any advice on both the hub and feelings on what would happen w/ that prop?) I'm also looking at getting a 3 blade 13 3/4?-14 vortex Aluminum (SS just too costly for an ol pontoon in my mind) so the insert will kill 2 birds w/ one stone...
bottom line I will probably keep the 14-21 (got an old Chris-Craft deckboat w/ the Merc 470 that I may refurbish.. yea right
) and the new replacement for the 14-11 which seems only a bit off (If I solve the cavitation)
