90hp evinrude leaking water
casey2001
i have a 1993 90hp evinrude and i was running it in the yard on the hose and i noticed a little bit of water squirting out, above the water intake holes where the gear case bolts to the rest of the motor. It wasnt alot but i figured it would only get worse.....im not sure should i leave it or fix it....can i drop the lower unit and put some gasket maker in between the two? how do i drop the lower unit there are 4 bolts holding the 2 together do i just taker the 4 bolts out...then will it seperate or is there more involved.
if anyone can help it would be appreciated
thank
D
DJ
Guest
Re: 90hp evinrude leaking water
Normal.
There is no seal between the lower and mid section.
D
DJ
Guest
Yes.
As stated, ther is NO seal between the lower and mid section. "Muffs" tend to push water out of that seam.
