Re: 90hp Evinrude powerhead on sea drive
I've picked up the new (to me) outboard and started tearing into it. It's an Evinrude "88 SPL" model E88MSLCCC. It lost the rings on one piston so at least that hole will need bored. The other three look pretty good. Other than that, everything is in very good shape. It apparently had never been in salt water so all the bolts came out nice and easy. I've been comparing my pile of Evinrude parts to my pile of Sea Drive parts and have come up with a list of questions.
1. So far, I don't see why I can't use the outboard shift and throttle linkage. It looks like a much simpler design than the SD setup. The cables enter at the same spot but are mounted further forward on the outboard compared to the SD. Is there any reason to use the SD stuff instead?
2. The lower pan and upper covers are different between the two. The SD has vents on the side and a sealed up lower pan. The outboard has no side vents but does have a vent on the bottom. Which pan/cover setup should I use? Would the outboard setup help prevent the water ingestion that made my SD main bearings blow up in the first place?
3. The SD has the upgraded VRO2 pump, but it has not been used for several years. The outboard does not have a VRO, just the single pump which was used only 9 months ago and worked fine. Should I keep the VRO or mix in the tank?
4. It looks like the outboard has the unregulated charging system. The SD has the regulated system. I'd guess that I should use the regulated system from the SD?
5. Which carbs should I use? Any idea if they are the same between the two? Whichever set I use, they'll get a rebuild before use.
6. What is an 88SPL anyway? With the lack of a VRO and unregulated charging system, is it just a stripped down version of a standard V4 outboard?
For reference, this is all being used on a 18' Tiderunner boat. It'll probably see some duty in salt water.
Sorry for the long post. Any advise would be greatly appriciated!
