OK I have a 1986 90hp Johnson. VRO removed. It was running rough last year. The blub would get soft, would take a long time after starting to rev up even with fast idle all the way up and it would take a long time to get to wot speed.. So I'm off season I did a fuel pump kit, fuel line O ring, and both carbs with carb kit. The blub stays hard now. It also starts much better. However it still seem to take longer then it should to get to wot. Examale being if you max the throttle it's takes a while to get the boat planing. At lower speed the motor will some times shake like it's running rough. The other thing Ive noticed is the exhaust smell strongly of gas. It sometimes seems also like it's misting gas out of the exhaust.
Anyway so my question is could it be running really rich? If so what's the best way to check or fix this. Or could this be the fuel tank is not venting properly?
Thanks for any thoughts.
